1998 WS6 Speedometer doesn't work
Old 12-25-2015, 11:02 PM
4.0Whipple03's Avatar
Default 1998 WS6 Speedometer doesn't work
I have a 98 ws6 and the speedometer does not work, every other gauge works fine, replaced VSS and no luck, it is working if u have it hooked to a snap on scanner it reads the vehicle speed so I assume the VSS is working ok, we have looked at most of the wires to computer and cluster all checks out good any ideas
Old 12-26-2015, 08:01 PM
clinebarger's Avatar
Is the Odometer/Trip counting? If so, The Speedometer stepper motor is bad.
If they are not counting, Check the 4000K Output wire between the Cluster & PCM.
Dark Green/White, Circuit # 617.....Between Pin 55 of the C1 PCM connector & Pin B12 of the Cluster Connector.
Check for continuity, Short to ground & Short to power, This circuit also goes to the Radio, I have seen radio installs go wrong & short the VSS signal wire to ground...Stooping the Speedo.....
Quick Reply: 1998 WS6 Speedometer doesn't work
