Converter pushing forward taking out thrust bearing??
Hello guys going to need little help with with this one
My combo is
Engine is on pump e85
365ls/lq9, lunati pro series crank,lunati pro ibeam rods, wiesco pistons.
trick flow 255 heads solid roller cam.
main bearing clearance was .0033 on mains and .0028 on rods. thrust was at .005. block was line bored, and square deck.
I drill rear thrust bearing with a 1/16 hole directly into oil galley of the bearing to force feed oil to thrust surface.
Twin 62/66 precision turbos set at 28.3 psi at full boost.
4l80e with d3 trans brake built for 1500hp+- pro yank 3400 stall
The car has went 9.3 @ 147mph with 1.4 60ft leaving the line at 3600rpm 7psi.
boost peaking at 14.8psi(just a few shake down runs with this combo)
Boost is now set at 28psi, have not been back to track yet before engine was hurt
Oil pressure dropped when car was on dyno 2weeks ago. pulled apart and found rear thurst metal to metal.. crank was moving .021 front to back.
Wondering if converter is pushing on crank/ converter is about 1/8 from flex plate when unbolted.
What can i do to stop this from happening?
Thanks guys
My combo is
Thanks guys
4L80E has a converter charge pressure relief. So it's really unlikely that the transmission is the cause.
You can check the cooler circuit pressure on the transmission outlet line and see if the cooler is causing a restriction.
Under power,
A converter becomes a pump. It will make its own internal pressure. Most converters have some design features to help prevent too much pressure.
More power creates more potential pressure. Turbo combos are more problematic due to time on the brake spooling.
You might try an external relief valve.
It could also be a simple engine assembly issue.
Under power,
I lost one on my last engine with boost-I figured it was either charge pressure or converter balloon-when I rebuilt the new trans I did the pump mod for less charge pressure, converter with balloon plate, and a mont. for charge pressure, hope for the best-my trans was a 400 though
LS1Tech Sponsor
Crankshaft Thrust Bearing Failure: Causes and Remedies
Although thrust bearings run on a thin film of oil, just like radial journal (connecting rod and main) bearings, thrust bearings can't support nearly as much load. While radial bearings can carry loads measured in thousands of pounds per square inch of projected bearing area, thrust bearings can only support loads of a few hundred pounds per square inch.
Radial journal bearings develop their higher load capacity from the way the curved surfaces of the bearing and journal meet to form a wedge. Shaft rotation pulls oil into this wedge-shaped area of the clearance space to create an oil film which actually supports the shaft.
Thrust bearings typically consist of two flat mating surfaces, with no natural wedge shape in the clearance space to allow an oil film to form, and support the load.
Conventional thrust bearings are made by adding flanges at the ends of a radial journal bearing. This provides ease in assembly and has been used successfully for many years. Both teardrop or through grooves on the flange face, and wedge shaped ramps at each parting line, allow oil to enter between the shaft and bearing surfaces.
But the surface of the shaft and the vast majority of bearing surfaces are flat. This flatness makes it more difficult to create and maintain an oil film. For example, suppose two gauge blocks had a thin film of oil on them. If you were to press them together with a twisting action, the blocks would stick together.
This is similar to what happens when a thrust load is applied to the end of a crankshaft: Oil squeezes out from between the shaft and bearing surfaces. If there's too much load, the oil film collapses and the surfaces want to stick together, which causes a wiping action, and ultimately, bearing failure.
This is why many heavy-duty diesel engines use separate thrust washers, each with a contoured face: to enable them to support higher thrust loads. These thrust washers either have multiple tapered ramps and relatively small flat pads, or they have curved surfaces that follow a sine-wave contour around the outer edge.
Recent Developments
In the past few years, some new automotive engine designs have included contoured thrust bearings. This change enables them to carry higher thrust loads imposed by some of the newer automatic transmissions. Since it's impractical to use contoured faces on one-piece flanged thrust bearings, these new engine designs use either separate thrust washers, or a flanged bearing, which is a three-piece assembly.
Cause of Failure
Aside from the obvious causes, such as dirt contamination and misassembly, there are only three common factors which generally cause thrust bearing failures:
Poor crankshaft surface finish
Misalignment
Overloading
Surface Finish
Crankshaft thrust faces are difficult to grind because they are done using the side of the grinding wheel. Grinding marks left on the crankshaft face produce a visual swirl, or sunburst pattern. The scratches sometimes crisscross one another in a cross-hatch pattern similar to hone marks on a cylinder wall.
If these grinding marks are not completely removed by polishing, they will remove the oil film from the surface of the thrust bearing, much like multiple windshield wiper blades. A properly-finished crankshaft thrust face should have only very fine polishing marks that go around the thrust surface in a circular pattern.
Alignment
Under normal circumstances, a remanufactured crankshaft does not require grinding of the thrust face surfaces. There are, however, situations where grinding is necessary. One is the automatic oversize of a thrust flange main bearing, required by using undersized crankshaft main journals.
A second occurs when thrust surface wear (front and rear) is beyond allowable specifications. This situation often requires an oversize thrust flange bearing or washer, if one is available for that application. Under these conditions, the thrust face of the crankshaft will require oversize grinding. In this case, crankshaft end float should be calculated and determined prior to grinding additional material from the thrust face.
Grinding the thrust face of the crankshaft presents a challenge, because the crankshaft remanufacturer has to use the side of the grinding wheel, which is not specifically designed for metal surface removal.
In addition, keeping enough coolant between the thrust surface and the wheel (just as keeping oil for lubrication within the engine) is difficult, and that combination creates a danger of wheel loading and burn spots. The result: an inconsistent thrust surface. To avoid this situation, the grinding wheel must be dressed periodically, to maintain a 90° angle, perpendicular to the centerline of the grinding wheel. This transfers to the same 90° angle between the thrust surface and the centerline of the crankshaft.
During the grinding process, the grinding wheel must feed into the thrust face very slowly and be allowed to spark out completely. If the grinding wheel does not cut cleanly, it may create hot spots on the crankshaft, leading to a wavy, out-of-flat surface. It is important to avoid excessive grinding of the thrust surface; this procedure is intended primarily for surface clean up.
When Assembling Thrust Bearings:
Tighten the main cap bolts to about 10 to 15 ft-lbs in order to seat the bearings; then loosen the cap bolts.
Tap the main cap toward the rear of the engine with a soft faced hammer.
Thread the main cap bolts in finger tight.
Use a bar to force the crankshaft as far forward in the block as possible, to align the bearing rear thrust faces.
While holding the crankshaft forward, tighten the main cap bolts to 10 to 15 ft-lbs.
Complete tightening the main cap bolts to specifications in two or three equal steps.
This procedure should align the bearing thrust faces with the crankshaft, to provide the maximum bearing contact for load carrying.
Loading
A number of factors may contribute to wear and overloading of a thrust bearing, such as:
Too much torque converter pressure.
Improper clutch release bearing adjustment.
Riding the clutch pedal.
Excessive crankshaft load pressure due to a malfunctioning front-mounted accessory drive.
Poor crankshaft surface geometry
External overloading due to:
Note: There are other, commonly-thought issues such as torque converter ballooning, the wrong flexplate bolts, the wrong torque converter, the pump gears being installed backward or the torque converter not installed completely. Although all of these problems will cause undue force on the crankshaft thrust surface, it will also cause the same force on the pump gears, since all of these problems will put equal force in both directions from the torque converter. So any of these conditions should also cause serious pump damage very quickly (within minutes or hours).
Diagnosing the Problem
By the time a thrust bearing failure becomes evident, the parts have usually been so severely damaged there's little if any evidence of the cause. The bearing is generally worn into the steel backing, which has severely worn the crankshaft thrust face as well. The following is a list of factors to consider while diagnosing the cause.
Engine-Related Problems
Is there evidence of distress anywhere else in the engine that would indicate a lubrication problem or foreign particle contamination?
Were the correct bearing shells installed, and were they installed correctly?
If the thrust bearing is in an end position, was the adjacent oil seal installed correctly? An incorrectly installed rope seal can cause enough heat to affect bearing lubrication.
Examine the front thrust face on the crankshaft for surface finish and geometry. This may give an indication of the original quality of the failed face.
Once you're satisfied that all potential internal sources have been eliminated, ask about potential external sources, such as overloading or misalignment.
Transmission Related Problems
Did the engine have a prior thrust bearing failure?
What external parts were replaced?
Were any performance modifications made to the transmission?
Was an additional cooler installed for the transmission?
Was the correct flexplate used? At installation, there should be at least 1/16" (1/8" preferred, 3/16" maximum) clearance between the flexplate and converter, to allow for converter expansion.
Was the transmission aligned to the engine properly?
Were all dowel pins in place?
Was the transmission-to-cooler pressure too high? If the return line has very low pressure compared to the transmission-to-cooler line, check for a restricted cooler or cooler lines.
If a manual transmission was installed, was the clutch release bearing adjusted properly?
What condition was the clutch release bearing in? A worn or overheated clutch release bearing that's adjusted properly may indicate the operator was "riding the clutch."
Recent Developments
Cause of Failure
Misalignment
Overloading
Surface Finish
Alignment
Loading
__________________
LS1Tech Sponsor
How does the Torque Converter Exert Force on the Crankshaft?
There are many theories on this subject, ranging from converter ballooning to spline lock. Most of these theories have little real basis, and rely little on fact.
The force on the crankshaft from the torque converter is simple: It's based on the same principle as a servo piston or any other hydraulic component: Pressure, multiplied by area, equals force.
The pressure part is easy: It's simply the internal torque converter pressure. The area is a little more tricky. The area that's part of this equation is the difference between the area of the front half of the converter and the rear half. The oil pressure does exert a force that tries to expand the converter like a balloon (which is why converter ballooning is often blamed); however, the forward force on the crankshaft occurs because the front of the converter has more surface area than the rear (the converter neck is open). This difference in area is equal to the area of the inside of the converter neck.
The most common scenario is the THM 400 used behind a big-block Chevy. General Motors claims this engine is designed to sustain a force of 210 pounds on the crankshaft. The inside diameter of the converter hub can vary from 1.50" to 1.64". Therefore, the area of the inside of the hub can vary from 1.77 square inches to 2.11 square inches. 210 pound of force, divided by these two figures offers an internal torque converter pressure of 119 PSI to 100 PSI, respectively.
So, depending on the inside diameter of the hub, it takes between 100 to 119 PSI of internal converter pressure to achieve a forward thrust of 210 pounds. The best place to measure this pressure is the outgoing cooler line at the transmission, because it's the closest point to the internal converter pressure. The pressure gauge must be teed in, to allow the cooler circuit to flow. Normal cooler line pressure will range from 50 PSI to 80 PSI, under a load, in drive: Far too low to create a forward thrust of 210 pounds.
Causes for Excessive Torque Converter Pressure
There are two main causes for excess torque converter pressure: restrictions in the cooler circuit, and modifications or failures that cause high line pressure.
One step for combating restrictions in the cooler circuit is to run larger cooler lines. Another is to install an additional cooler in parallel with the original, rather than in series. This will increase cooler flow considerably. An additional benefit to running the cooler in parallel is it reduces the risk of overcooling the oil in the winter. The in-parallel cooler may freeze up under very cold conditions; however, the cooler tank in the radiator will still flow freely.
Modifications that can result in higher-than-normal converter pressure include using an overly heavy pressure regulator spring, or excessive cross-drilling into the cooler charge circuit. Control problems such as a missing vacuum line or stuck modulator valve can also create high pressure.
What Will Help Thrust Bearings Survive?
A simple modification to the upper thrust bearing may be beneficial in some engines. Install the upper thrust bearing in the block to determine which thrust face is toward the rear of the engine. Use a small, fine tooth, flat file to increase the chamfer on the inside edge of the bearing parting line to about 0.040" (1 mm).
Click the image to open in full size.
Carefully file at the centrally located oil groove and stroke the file at an angle toward the rear thrust face only, as shown in the illustration. Avoid contacting the bearing surface with the end of the file. The enlarged chamfer will allow pressurized engine oil from the pre-existing groove to reach the loaded thrust face, without passing through the bearing clearance first (direct oiling).
Since there may be a load against the rear thrust face, oil flow should be restricted by that load, so there shouldn't be a noticeable loss of oil pressure. This modification is not a guaranteed cure-all, but it should help if all other conditions, such as surface finish, alignment, cleanliness and loading are within required limits.
Note: As with all modifications, it is important to find the original cause of the problem before making modifications. Failure to do so may result in a repeat failure.
Other External Problems
Aside from the items already mentioned, there is another external problem that should be addressed. Ground problems have been known to intensify thrust surface wear. Excessive current in the drivetrain can damage the thrust surface, which then affects the thrust bearing as though the thrust surface on the crank shaft isn't finished properly.
It's easy to check for excessive voltage in the drivetrain: Connect the negative lead of your DVOM to the negative post of the battery, and the positive lead to the transmission. You should see no more than 0.1 volts on your meter while the starter is cranking.
For an accurate test, the starter must operate for at least four seconds. It may be necessary to disable the ignition system so the engine won't start during the test.
If the voltage is excessive, check or replace the negative battery cable, or add ground straps from the engine to the frame, or the transmission to the frame.
Some systems may reach 0.3 volts momentarily without having a problem. For added assurance, improve the ground with a larger battery cable or additional ground straps.
Although the greatest current draw is usually while the starter is cranking, current in the drivetrain can occur while accessories are operating. That's why you should perform this voltage-drop test with the ignition on, and as many accessories operating as possible. Again, the threshold is 0.1 volt.
One final problem that may occur is current though the drivetrain, without measurable voltage. If the grounding problem is in the chassis but the engine and transmission ground is okay (or vice-versa), the vehicle may pass the test. What happens here is the ground circuit can be completed through the drive shaft and suspension.
To test this, measure the voltage drop with the drive shaft removed. Both the drivetrain and frame must pass the 0.1 volt test. This is where a ground strap from the engine or transmission to the frame does its best work.
Summary
As with most problems, rarely is one solution the answer for all examples. It is attention to detail and rebuild procedures that include many details that ensure success. The intent of this article is to include the most likely causes for crankshaft thrust failure, as well as dispel some of the myths and mysteries surrounding it.
__________________
Summary
__________________
__________________
It can,
But typically if it's within a certain range it won't change. Too low pressure can affect it.
There are different theories on converter pressure.
Lots of testing has been done using different methods to control fluid pressure and flow into and out of the converter to change stall. Drag radial classes are the forefront of this at the moment.
I recently did some extensive testing on 4L80E charge pressure because we had a customer with a hurt thrust shortly after installing a 4L80E.
I see the converter charge pressure and flow on a transmission dyno daily.
However we did some unusual testing to check pressures inside the converter instead of on the cooler circuit. Interesting results.
not to beat a dead horse but. you guys that rebuild th400s, have you ever seen the splines on the forward clutch hub beat up, the bearing on the rear internal gear to output shaft bad, #22, and the case washers burned every action has an equal and opposit reaction. ask youself, what causes that?
