4l80e stand alone controller which one is the best
Old 07-18-2016, 04:21 PM
turbo69's Avatar
Default 4l80e stand alone controller which one is the best
which stand alone controller is best?
Old 07-18-2016, 06:03 PM
forcd ind's Avatar
The best one is the one somebody is using, you know that.
I have only used the Compushift controller, I have used 3 of them, and they are packed with features-they are more expensive than most
Some of the controllers you have to buy the harness sep, and the price goes up
I guess its all in what features you want-I likes the CC display screen, lots of configurations you can do
Old 07-19-2016, 06:52 PM
Moderator
mrvedit's Avatar
Is your turbo carburated?
If not, what ECM/PCM are you using?
If you have a GM ECM/PCM then you should be all set (might need a TCM to match the ECM). Then use HP Tuners to tune the trans; this is cheaper than buying a stand-alone trans controller.
Old 07-20-2016, 11:57 AM
turbo69's Avatar
I am going to run the ms gold box. I do have the stock wiring and pcm but dont want to run it.
Old 07-24-2016, 06:07 AM
aknovaman's Avatar
Microsquirt or us shift.
Quick Reply: 4l80e stand alone controller which one is the best
