Stock 4L80e torque converter ?
Anyone using a stock 4L80e converter in their street car ?
I have a 6.0L with the "hot cam" 219/228 .525 lift. Going in a 68 Camaro convertible.
Is there enough "stall" in the stock converter to be ok with this ?
LS1Tech Sponsor
Stall wise the stock converter should still idle and work with your cam but don't expect anything exciting from it from under throttle. comparing against one of SRL series again you could go with a 3000-3200 stall vs the stock 1600rpm and have some good performance under throttle while still maintaining great street drivability.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
I'm estimating it's 40 lbs. I'll get back and let you know soon.
