will Spohn solid motor mounts work with 4l80 conversion on my 4th gen?
I am in the process of doing a 4l80 conversion for my 98 TA and wondering if the current Spohn solid motor mounts I have are still going to work? I am doubtful due the height these mounts give the motor and the needed BFH mods I will have to do to the transmission tunnel to clear the 4l80 in place. Anybody used these together?
quick search and I found this post.
https://ls1tech.com/forums/automatic...l#post11478810
That should explain where and why to cut. Also if your transmission is an older model with the larger ears, those will need to be chopped or grinded off.
