2003 ext cab 1500 4l80e swap HELP
Can i use my stock drive shaft? what do i need to change? yoke? u joint? part numbers please?
HELPPPPP
i understand the cross member and wiring will need to be changed as well as the flex-plate
HELPPPPP
Trans
https://ls1tech.com/forums/conversio...l80e-size.html
Run through the link and it should answer most of your questions. Looks like the D-shaft is going to need modification.
