At last....
At last....
So, I've been dragging my feet over the past couple of months building my first
400. I finally got a little energy and decided to knock the build out today. And yes, the case looks nasty, but this is about as clean as I could get it......now the internals...spotless. All I have to do now is, get a set screw for the converter circuit restrictor...put the pump on and install. With all that said, I'm not liking these seals for the pump. Anyone of you guys use these with no issues?
You have to tighten the sealing rings so they hug the pump and make sure the rings overlap correctly, not like the lower one in the picture. Take the rings off the pump and make them into a smaller circle and spiral them onto the pump ring grooves so they are not protruding form the groove. Call me if you cannot figure it out.
