which size stall/torque converter
im debating on which stall/torque converter to get:
slp 2800 $424
yank 2600 $359
tci 3000 $439
keep in mind im on a tight budget, does the 2600-3000 really make that much of a difference, is it really worth $100 more. i dont race that often nor drive my baby that much
slp 2800 $424
yank 2600 $359
tci 3000 $439
in my opinions anything under a 3200 stall is pointless....3000 is marginal but to really see a gain in the car's performance, go with a 3500 or so....i love my 3800. driveability is still very good and the car pulls like crazy. if you're looking to spend under 500 bucks, you can't go wrong with a TCI Super Street Fighter 3500. these cars don't make any real power below 3000 rpm so they need a decently high stall to really get moving. the 2600 is NOT in any way worth paying for.
Originally Posted by platinum310
dont i need better gears though, i only have 3.23
i know of guys going 11s (maybe faster) still on 3.23s. trust me on this one, i don't know everything but i DO know that LS1s LOVE a 3200+ stall. slightly taller gears would help, but you're not gonna be mismatched or anything with the 3.23s still in there.
thanks guys, i will go with the tci3500 from texas speed for $519, it will still drive the same right? will it only increase power from a complete stop 2 go or on highways also
the converter will make the greatest difference from a stop (with traction of course) however you will get a slight boost from a roll too due to the fact that when you hammer it, the converter will downshift and flash to a much higher rpm then it used to. ya know that DEAD spot where you're just a little too fast to downshift to 1st? that will be reduced because the converter will flash up higher right off the bat. in addition your shift extension (the RPM that the motor drops TO after an upshift) will be higher, thus keeping the engine in its powerband ALL the way through each gear.
in short, you will probably (like i did) hate the converter for about the first 15 minutes of driving it. its a slightly awkward feeling at first. however the first time you romp on the gas from 20 mph and the tires go up in smoke, you will be QUITE happy.
The first time you drive a 3500 converter it goes like this...
Ick! What's wrong with my car?!? Is this normal? This CAN'T be good! Is the tranny slipping???
15 minutes later...
WOW!!! This thing hauls AZZ!!! NO MORE DEAD SPOT! Still kind of loose now but maybe it isn't so bad.
30 minutes later...
Feels fine now. I love it!
1 hour later...
Hmmm....I need stickier tires.
3 days later...
This thing feels almost stock to me now. Maybe I should have gone with the 3800?
15 minutes later...
30 minutes later...
1 hour later...
3 days later...
1 Post
15 minutes later...
30 minutes later...
1 hour later...
3 days later...
15 minutes later...
30 minutes later...
1 hour later...
3 days later...
15 minutes later...
30 minutes later...
1 hour later...
3 days later...
15 minutes later...
30 minutes later...
1 hour later...
3 days later...
Exactly..
Just get a Yank SS4000 and be done with it.
Originally Posted by Rick01SS
Exactly..
Colonel should know as I reckon hes tried every converter known to man and then perhaps some.
