will it hurt the trans to put a shift kit in and drive it without a tune?
I mean without taking the torque multiplacation out? I will just be driving it from the tranmission shop the the place to put the cam in I also will have a 4000 stall if put in if that matters
EDITING MY FIRST RESPONSE:
Just checked the Transgo website. There is a potential conflict between the Transgo and the stock PCM programming. Transgo recommends disabling TM to avoid this conflict.
So, yes, you should tune the PCM.
I have a 4000 stall and a shift kit without a tune right now. I ran the shift kit for a year without tuning and had no problems that I know of. I am scheduled to tune next week though and with that stall I recommend it. Also don't hold back on the washers when putting in the shift kit because after the stall the rough shifts tend to dissapear.
no I don't mean drive it for a week or two without a tune just from shop to shop what i am having work done so that i can have a tune done one time , it will all be tuned by the time all the work is done
