New Th400 Price $900 Good/bad
I HAVE AN A4, AND WANT TO GO WITH A BETTER TRANNY AT MOUNTER MOTORSPORTS THEY ARE SELLING A RACING TH400 FOR $900, IS THAT A GOOD PRICE FOR THIS
√ PRECISION MASTER OVERHAUL KIT
• New Gaskets, Seals, O-rings, Teflon rings
• New Governor Filter
• New Rubber Seals for Drums & Pistons
• New High Performance Friction Clutches
• New Steel Friction Plates
• New Steel Check *****
• New Double Lip Seals (Front & Rear)
• New Alto Red Eagle Race Clutches
• New Brass Washer Kit "NO PLASTIC HERE"
• New Bushings & Torrington Bearings
√ SUPERIOR HIGH PERFORMANCE REPROGRAMMING SHIFT KIT
√ SUPER PUMP
• New Pump Bushing
• New Stator bushings & sealing rings
• Modified Boost Valve Assembly
• New Boost Valve Spring
√ DIRECT/REVERSE INPUT DRUM
• Machined surface for Maximum Band Performance
• Spun balanced & checked
• New 34 element roller sprag
• New smooth cam drum assembly
√ FORWARD CLUTCH HOUSING
• Thoroughly checked & inspected Spline, Drum casting
√ UPDATED/MODIFIED ACCUMULATORS
√ RAYBESTOS PRO SERIES KEVLAR BAND
• High-Temp. Tolerant
• Improved holding power
• Added strength at Strut Support
√ UPDATED & MODIFIED GOVERNOR w/SPRING KIT & NYLON GEAR
√ RECALIBRATED VALVEBODY
√ RECALIBRATED VALVE PLATE FOR SHIFT FIRMNESS
√ NEW HIGH FLOW FILTER
√ NEW LOW/REVERSE HEAVY DUTY SPRAG
√ NEW HEAVY DUTY ACCUMULATOR SPRING
√ NEW MODULATOR
WHAT ELSE WOULD I NEED FOR A COMPLETE INSTALLATION
√ SUPER PUMP
• New Pump Bushing
√ NEW MODULATOR
thats about what summit/jegs sells th400s, but they are name brands. not that the one you are interested in is junk. keep in mind that any th400 is stronger than a 4l60e.
sounds like a pretty good price to me. that's a couple hundred less than what I paid for all of the same stuff, only mine came with a Hughes trans brake. Sounds like a decent deal to me.
