TH400 - stick with stock 2.48 or upgrade to 2.75 first gear
this will go behind at 408ci, 3.73 gears, transbrake with 4000 stall and a 200 shot. Is it worth it to upgrade to the 2.75? Will this make driveablity without OD "better." Will it help when foot braking when spraying or will I get too much spin.
I read that the 2.48 bogs HARD on launch.
You guys should stick with the 2.48. The 408ci motor plus the nitrous will make so much torque, then add the multiplier of a 2.75 1st gear and you'll never hook and if you do, you'll wish you had whellie bars on the car. I highly recommend you stick with a 2.48 1st gear!!
2.75's
Originally Posted by ATVracr
I'm getting the 2.75-1.57 upgrade on my th400 coming from Coan soon. I have a 346 H/C and will be hitting it with the 200 shot also.
I dont see how it would hurt drivability, still 1to1 in 3rd thats all that matters really.
Going to a wider gear spacing can hurt you at the track by putting you outside the powerband after a shift. Closer gear ratios can be a benefit because it allows you to cam for a shorter more intense powerband. Then you dial the rest of your setup by choosing the right rearend gears & tire size. I'm sure you guys understand all of this already. I'm posting this for those that may not realize it.
Sorry to bring this thread back from the dead, but was just searching.
Would the 2.75 be better for a turbo car to help it get out of the hole considering the low compression and lag? Especially on a larger turbo such as a T-88, or T-76.
Thanks,
Josh
Thanks,
Josh
Thanks,
Josh
Thanks,
Josh
Not really, no. What you need for a turbo motor is a torque converter with a high stall-speed. For the turbo you need to be able to bring the RPMs up in a brakestand to spool up the turbo. While standing still gearing has no affect on this ability - it's the torque converter letting it happen.
Thanks,
Josh
Thanks,
Josh
I'm running stock cubes, so I know it won't be quite as ridicolous off the line as a 400+ cubic inch motor. However, the tranny I'm considering does have a transbrake, which should get me leaving pretty damn hard regardless of the first gear ratio.
Thanks a ton the advice,
Josh
Josh
