To change or not to change....
Old 12-19-2004, 02:35 PM
dcrews's Avatar
Default To change or not to change....
Ok, here's the deal.. I have a 98 T/A with the 4l60e..
It has 121k miles on it, and I was pondering changing the trans fluid. It looks red/brownish and smells bad, so I figure it's about time, since I have no idea on prior maintence..
BUT...... I've heard that changing it at this stage in the game may do more harm than good..
I was thinking of changing the filter and filling it back up with Valvoline Max-Life trans fluid.
Any ideas/comments/suggestions?
Oh yeah, as of now, it shifts ok, not great, but ok. So I don't know if this will hurt or not..
Thanks!!!
Dan
Old 12-19-2004, 02:57 PM
Pontiacerator
RevGTO's Avatar
I wouldn't if I were you. I did it once on a 65 LeMans with high miles and immediately afterwards it started slipping badly, and that was all she wrote ... in high-mileage trannies, the gunk helps keep 'em together.
Old 12-19-2004, 09:09 PM
LT1Burnout's Avatar
i find this VERY interesting. for some reason i just kept pushing off a fluid and filter change, then it started leaking from the pan gasket which in turn motivated me to do it.. i changed my 4L60E trans fluid after 133k, soon after it started slipping, cooking, then took a dive and needed a rebuild. coincidence??
Old 12-20-2004, 12:30 AM
Pontiacerator
RevGTO's Avatar
Originally Posted by LT1Burnout
coincidence??
Nope.
Old 12-20-2004, 01:21 AM
Casper9T9's Avatar
You either change it regularly or don't change it at all.
Old 12-20-2004, 04:56 PM
LT1Burnout's Avatar
