Is Vig 2800 Right For Me
Old 12-20-2004, 03:33 AM
02 wife's Avatar
Default Is Vig 2800 Right For Me
Hello all I am A New Member To Ls1 Tech. I Have A 2002 Camaro Z28 A4 With 2.73 Gears. Would A Vig 2800 Be A Good Choice For Me. I Only Visit The Local Track A Few Times A Year. I Want To Maintan Good Driving Manners, But Have Just A Little More Punch Out The Hole. Car Is Stock With A Magnafow Muffler , And Whisper Lid. I have gone a best of 13.43 at 104 mph in the 1/4 with my basic setup. Any Advice Would Be Appreciated.
Old 12-20-2004, 12:48 PM
SmokingWS6's Avatar
PI makes excelent converters. A lot of folks will tell you to step it up to a 3200, but if yours is just a driver i'd say go for the 2800. It'll be a huge improvement over the stock converter. I have a 3200 and anything under 40mph street tires are pretty useless
Old 12-20-2004, 01:35 PM
Debian Dog's Avatar
Get a bigger one or you will be sorry. I just stepped up from a 3000 to a 3800 and it is still a great daily driver IMHO.
Oh and if you want a Yank 3000TT with 2.5 STR PM me.
Old 12-20-2004, 01:47 PM
TWISTEDTA's Avatar
OK im new also at the stall converter stuff i had a built 5 speed in my iroc. So when you get a stall does it mean every single time you step on the gass the R's will hit w.e the stall is rated at? or that only apply's when your off the line and want to stall it with the brake?
Old 12-20-2004, 01:52 PM
Debian Dog's Avatar
No it will go higher but it kind of is dependent of a lot of things. The stock stall is like 1900 but you car starts moving BEFORE that right? (Brake vs. Flash stall) Here is a good read:
http://www.converter.cc/faq.htm
Old 12-20-2004, 01:57 PM
TWISTEDTA's Avatar
Thanks bro helped alot
Old 12-20-2004, 02:15 PM
Debian Dog's Avatar
No prob....
I was confused at first and worried to much about getting to big of a stall. Actually the 3000TT hits nicer down low but the new SS3800 feels better up top.
Old 12-20-2004, 03:08 PM
cablebandit's Avatar
2800-3200 would be great. 2800 will feel like stock until you romp on it. 3200 may be a little much if you REALLY only go to the track a few times a year.
Old 12-20-2004, 04:10 PM
02 wife's Avatar
Thanks for the input. Its a daily driver so I will most likely get a Vig 2800 ,with 24000 trans cooler.
Old 12-21-2004, 05:41 PM
2002 Trans Am's Avatar
Originally Posted by Debian Dog
No prob....
I believe the TT series has a 3.0 str which should hit real hard, the SS3600 has I believe a 2.25 str and the 3600-4000 has a 2.55 str, the slightly lower str does help when pounding on the gas with stock tires, and that **** does pull hard up top
Old 12-21-2004, 06:48 PM
XtinctHawk02's Avatar
i have a Vig. 2800 and absolutely love it. Eventually I will probably step up to a 3200, but i'm in no big hurry.
Old 12-21-2004, 07:18 PM
02 wife's Avatar
Thanks For The Info.
Old 12-21-2004, 09:28 PM
TWISTEDTA's Avatar
So 2800 would be good for me? I read some were that its good to keep a stall about 4-500 R's from the power band, Im not even sure were mine starts! I think a 2800 sounds good though any advise?
Old 12-21-2004, 09:43 PM
LS1FIRE's Avatar
I would get a 3200. I wouldnt wanna regret going bigger after its installed.
Old 12-21-2004, 09:55 PM
02 wife's Avatar
What Size Stall You Got?
Old 12-21-2004, 10:54 PM
WILWAXU's Avatar
IMHO, the Vig 3200 is the lowest speed stall anyone should go with in a LS1 powered car.
The 2800 isn't a bad converter... but everyone I've known with one, upgraded or had it restalled ($$$).
Old 12-22-2004, 07:26 AM
TWISTEDTA's Avatar
Humm...ok, but keep in mind that i wanna drive this thing every day, and i probley wont even take to the track-maybe ones or twice. i just wanna have my car at peek performance withought it being too much ya know? Do any of you know were the power band kick's in or were the cam starts on these cars? Thanks guys
Old 12-22-2004, 07:35 AM
CrimeSScene's Avatar
The 2800 stall made my car scream and had great driving manners. That being said, I was looking to have it restalled to 3200 before I decided to just put in an M6.
Old 12-22-2004, 08:27 AM
ArcticFormula's Avatar
I'm going with the vig 2800. I'm running street tires and want good drivablity. Car goes into the shop in about 3 weeks for the verter and some other goodies as well .
Old 12-22-2004, 09:03 AM
Debian Dog's Avatar
Opps... I think your right! Thing does hit like a bi*ch which is surpizing on a 2.73 geared car. I could run NOTHING but DR's if I wanted traction.
