Generation V Internal Engine 2013-20xx LT1
Gen V L83 oilpan
Old May 6, 2024 | 02:08 AM
tonn0297's Avatar
Cool Gen V L83 oilpan
Hello, im looking arround and i can't find any resonable front sump oilpan for a L83?
Do any have a idea where to look or do i have to make my own? The LOJ one is nice but im not paying 1500$ +25% taxes in my country for it...
Its gooing on a 1973 ranchero, it original have steering behind crossmember, that makes so i can't run a rear sump. ill post some pictures.
Old May 6, 2024 | 02:25 AM
tonn0297's Avatar
Default A few pictures
Old May 6, 2024 | 04:43 AM
Scott Danforth's Avatar
could start with an LS4 pan and modify it into a front sump
Old May 6, 2024 | 05:08 AM
tonn0297's Avatar
Thanks, but the LS4 do not fit a LT(L83). There's countless LS based front sump but none for the LT
Old May 6, 2024 | 07:14 AM
Scarebird's Avatar
I have a L84 in my Lemans. I noted that it would not be that difficult to mod to a front sump configuration.
Old May 6, 2024 | 07:17 AM
tonn0297's Avatar
Yea that's very true, I wuld like to just get one, insted of modifying a exspensive pan anyway 😅
Old May 6, 2024 | 07:22 AM
Scarebird's Avatar
I would just mod a stock pan. I assume shearing, forming and welding aluminum is still a thing in Denmark?
Old May 6, 2024 | 07:29 AM
tonn0297's Avatar
I've Thught about it alot, is the cast that the pan is made of weldable?
Old May 6, 2024 | 07:37 AM
Scarebird's Avatar
My guess is yes - I would trim off a small, non-essential piece and have a shop test weld it for you.
Old May 14, 2024 | 12:08 PM
Tondo's Avatar
Share pictures ?
Old May 22, 2024 | 11:21 AM
Forcefed86's Avatar
Prob easier to modify the K-member and steering rod to accept the pan you have VS making a pan. on a similar setup I just welded on some 4" spacers on the steering shaft, then cur the center out.
Or move to a front mount rack.
