th400 and torque arm
I've got a 95 z and I was wondering if anyone made a torque arm that will work with a th400 and a moser rear end? Also, If I currently have a six speed, do I need a crossmember for the th400? Where can I get one?
thanks guys
thanks guys
1 Post
Check out Spohn for the torque arm ->
You should be able to use your crossmember with a poly mount (also available from Spohn), but you will probably need to make up a spacer to get your angle right.
I have a Spohn TA, and we are using an M6 crossmember and Spohn mount to put the TH400 in my car - I don't think there is any difference between the LS1 and LT1 crossmembers is there?
I used the the hurst kit to convert from a 700r4 to TH400. You need to drill some holes in order for the torque arm to fit up right with it but other than that it has been great. I have cut 1.50 60' with that set up with a BMR adjustable torque arm I had before the TH400 swap. I also have a moser 12 bolt and everything came out perfect.
juiced,, when we changed over a 95 m6 to a th400 the crossmemebr was the same,, you dont have to get a diff one,, also,,spohn makes a real nice torque are that doesnt bolt to the trans,, .. let me know what you going to do with that m6,, i need one for one of my cars..
