Tool for A4 guys
Tool for A4 guys
Made this tool to hold crank from spinning when removing harmonic balancer. Big pins for stock pulley & 3 bolts for ASP pulley. $40.00 for tool, shipping has been running $15-17.00.
after market pulley
stock pulley
after market pulley
stock pulley
Tool yes, dog no. Nineball said it was alright or did I violate some other rule? Did your car sell? We were seriously considering driving down there to get it.
Yeah, the car is gone
Yeah M6 guys can just throw it in gear but a I guess there could be exceptions, doing clutch work at the same time or maybe having the tranny out of the car while working on the engine? Using this on A4's would prevent you from having to drop the starter or using an impact.
Originally Posted by DrkPhx
Am I missing something here or how can you use this tool when loosening or tightening the crank pulley bolt to 240 ft-lbs with one hand?
That tool would have worked aa lot quicker and more easily than having to drop the starter and shove a screwdriver into the flywheel. Would work great with the car on the ground. How long is the arm? Will it reach the floor with the front of the car on jackstands? I'm guessing no by the looks of it. Make the arm long enough to reach or find a way to make it that will allow you to keep it stationary without fabbing something up yourself and you'll be set.
Originally Posted by blkZ28spt
Just an FYI: Most people will tell you not to use an impact to remove the crank bolt. EVERYBODY will tell you not to use it to install it.
It hangs down 23 inches from the center of the pulley bolt. So it depends how high you have the jackstands.
Man, six months ago I built something similar to install the balancer that came with a Vortech kit.
Just drill a steel plate and weld a bar on it.
I'm happy to see I wasn't the only one with that idea!
My bar was much longer so I was able to torque the front bolt alone.
