1-2 shift bangin HARD REV lim
Old 01-14-2005, 01:05 AM
99PTA's Avatar
Default 1-2 shift bangin HARD REV lim
I had problems with bangin my rev limiter when i went from 16 to 18 inch rims.... so i had a shop use LS1 edit to change my shift points ... prob fixed.... a couple of days ago my battery almost died and all the gauges reset and everthing..... a day later i went to race and from 1-2 i slammed the rev lim everytime... did it reset my tune or is my clutch pack gone.... PS Trans fluid pink.... no brown and not black spots or anythin looks normal
Old 01-14-2005, 07:15 AM
sleeperstyle's Avatar
i don't think your tune was re-set (it can't be, it is flashed into your computer chip. there is no "old tune" to re-set to).
i would suspect tuning though. odd that it happened after your battery cable off.
Old 01-14-2005, 09:35 AM
MeanWS6's Avatar
sounds like your bands are glazed
do you have autotap to see what the gears are doing at WOT
Old 01-14-2005, 04:58 PM
99PTA's Avatar
No i dont have an autotap.... explain "Glazed" and if i had an autotap what would i look for?
Ps... 2-3 shift is fine.
