Question on High stall (3000-3500) on Stock Heads/cam
I was told, My car being a 94 LT1..Does not Work well with a high stall, With the stock Heads/Cam...I was told that I should not go over 2600 as long as i have the stock Heads/Cam, because it wouldnt "utilize my sweet spot"...Im looking for guys who know LT1's to help me out here..being that LS1's have MUCH different heads...What do you think?? is this true? Should I stick with a smaller stall?
and BTW...my formula has bolt-ons, 3.73's, Fresh performance build on tranny, free mods
a 94 wont make a 1-2 shift with much over 2800 stall. It will set a speedo sensor code and defaults to 3rd. The reason for this is the pcm on OBD1 shifts ONLY off MPH at part and WOT. OBD2 uses rpm setpoints for shifting at WOT so its not a problem.
A 2800 vig. will work very well with a stockish LT1
