Trans Jerking After TC Install
Old 02-26-2005, 10:48 PM
petekc's Avatar
Default Trans Jerking After TC Install
Just put in a Thundr Racing 24/24 Cam and a TCI 3000 tc.
I noticed that in Overdrive when I do NOT have my foot on the throttle or brake between 30-35 the car starts jerking and you can hear a slapping type noise under the car.
If I have it in Drive the same thing happens between 20-25 but NOT 30-35.
If I have my foot on the throttle in the least bit or on the brake it doesn't do it at all.
Is this just the PCM & TC not getting along at those spots or is the TC got an issue?
Thanks in advance
Old 02-27-2005, 04:11 PM
Ragtop 99's Avatar
Can you log the gear to see if the trans is downshifting or remaining in a high gear? I s the converter locked? It could be just a case of cam surge.
Old 02-27-2005, 10:13 PM
artic-z28's Avatar
probly the converter is locked and your rpm is low and your not accerlation.. .. mine does that... i think thats called TCI converter.. heh ..and some shutter...
Old 02-28-2005, 11:42 AM
Lady Redhawk's Avatar
Location: sojourning....looking for my city whose builder and maker is God.
Thanks in advance
As long as it is not the converter out of balance causing a viberation, tuning would take care of those issues. Not a hard tuning fix for your cam and TC.
