B&M Pro Stick install - pics
Old 03-04-2005, 06:45 PM
S_J_H's Avatar
Default B&M Pro Stick install - pics
I just installed a th400 and at the same time installed a B&M Pro Stick shifter.
I cut a mounting plate from 1/8" aluminum and drilled it to screw into the stock shifter holes in the car. The ProStick shifter is spaced up and then fastened to the plate.
Then fasten the shifter/plate to the car.
Had to drill a new hole for the cable to pass through and also trimmed the console cover for the shifter to pass through. Just used a dremel with cut off disks for that and then added some trim edging to finish it off. I think it turned out well.
It is fully possible to install the shifter without the aluminum cover and not have to trim the console area and you don't really need to space it up then. But I liked the look of the aluminum cover so I did it this way.
Steve
Old 03-07-2005, 01:14 AM
Sandmann120's Avatar
That looks pretty good. Any pics without the console in place?
Old 03-07-2005, 09:28 AM
Coal Mining Director
onfire's Avatar
Nice Install. RMVB?
Old 03-07-2005, 09:38 AM
S_J_H's Avatar
here you go.
Forward manual/auto as I like having engine braking.
Quick Reply: B&M Pro Stick install - pics
