TH 350 Guys look here
Originally Posted by jxaxsxoxn
The only con I can see is not running a dust cover that has strut rods on it for support.
That and I guess it could be dangerous if you're the type who likes to work under the car with the engine running.
I leave them off usually, or put a plastic one on so it doesn't rattle.
You can get them off ebay..Not knowing any better i had to get a chrome one to match my chrome pan for the bling..
What about rocks and debrie getting kicked up with it off?
I just remembered one thing though, One of the th350's in my nova blew a pump seal and slung fluid on the header, which was wrapped, and it started a fire. If I had the cover on there it would have prevented it from slinging out.
So if you have one use it.
BTW if you have one why do you ask?
Originally Posted by TJ
your front pump seal might have blown due to not having a dust cover. lots of stuff can get caked up in there.....
It had maybe 100 miles on it and I knew I should have redone that bushing because the converter was a tight fit, in fact I had to tap it in with a hammer.
See I know all the dumb mistakes because I've made most of them already.
No I drove the pump bushing in crooked and it loosened up while driving and pushed the seal lip out just enough.
its how i learn as well.
