AN ACTUAL TECH QUESTION/not which converter should i buy ?>
FOR those of you with the TCI deep trans pan/especially anyone with 1 1/2" drop/ how much clearance/any difference in trans temp change/is it worth it? obviously my Y pipe is ultra low, so i already take it easy.........hit me back with some actual information if you actually have/had one of these set ups, thanks.
Moderator
1" and I was hitting the drain bolt on every speedbump
in town, with the deepest TCI pan. That's a special
feeling, when you bang the trans dead down on
something. I took it off 'cause I figured if I was doing
to bang pan, I wanted a pan that would dent instead
of crack. Though the TCI deep finned one is stout.
If I were stock height I would still be using that pan.
But, damn.
But, damn.
