Whats the max HP a 2002 Z28 A4 stock tranny can safely handle?
Old 07-16-2005, 11:52 PM
kcfan's Avatar
Default Whats the max HP a 2002 Z28 A4 stock tranny can safely handle?
How much HP can a stock 2002 Z28 A4 tranny safely handle?
Old 07-17-2005, 12:20 AM
back4more's Avatar
3-400 ish depending how you drive it
Old 07-17-2005, 12:28 AM
farsighted770's Avatar
from what i have seen if you run them hard for long the 350 rwhp range is almost as far as you can push and not expect problems, i have put about that through mine and weekend raced it for almost 60000 miles, but now im replacing it and the car has about 113xxx on it so :dunno:
but i have also been told i was lucky, cuz there are some people out there who put that much to them and ruin the gear sprag soon as they start doin a lot of roll racing(manually dropping the transmission into gear)
another suggestion is if your ever gonna tune your car be wary of the transmission line pressure... make sure you dont over due it, and dont keep it too soft either(over doing it blows the sprag, and runnin it too soft burns up the clutches faster, least from what i understand... i could be wrong though) hope this helps.
as a warning most of this is only hearsay so your best bet would be talk to some performance shops, im sure some of this sites sponsers can really help you.
Old 07-17-2005, 12:37 AM
Scotty-Z's Avatar
It all depends. Some blow up early, others hold on and run high 10s for a long time. So it's really hard to say.
Quick Reply: Whats the max HP a 2002 Z28 A4 stock tranny can safely handle?
