Which stall?
Which stall?
Hey guys, i have a question, and i dont really know if it matters all that much but some say it helps your et. I have a 224/224 LSA cam by TR. I was wondering what stall would be the best with that set up. I as well have LS6, ASP, LT's, and a lid... i was planning on going with a yank ss3600, but jw if there are any suggestions on what stall to run with this set up. thanks ahead of time.
from a tranny guy
a general guidline from the tranny guys view point is that you want your stall to be at the lower rpm range of the cam. that is all cams give an rpm range that they make most power ( this is written on the cam card) that is where you want your stall to be so you are always in an rpm range where the motor makes peak power.
