Will a TH400 bolt directly to a '98 WS6?
Old 10-07-2005, 02:52 AM
MountainMotor's Avatar
Default Will a TH400 bolt directly to a '98 WS6?
Just wondering if a TH400 tranny would bolt directly into a '98 WS6 or would it require modifications to make it fit and work properly?
Old 10-07-2005, 08:09 AM
fasttagurl's Avatar
I think you need a custom driveshaft (around $350) and probably some other special parts.
Old 10-07-2005, 09:18 AM
gator's 99TA's Avatar
there is a stickey at the top of this forum. check it out.
Old 10-08-2005, 12:14 AM
Jimmy P's Avatar
No major modifications. Prety much new driveshaft, torque converter, speedo sensor if you want to keep your speedometer. As far as crossmember, you can put 1" worth of spacers on a M6 crossmember, or you can pay around $170 for an aftermarket th400 one. Oh yea, also a custom dip stick, from either Madman or Lokar.
Old 10-09-2005, 01:46 AM
So nothing too major?! As long as it's just a few smaller things it's no big deal. I'll check the stickey too.
Old 10-10-2005, 11:27 AM
john kilgore's Avatar
Default 400
check with mike at yank
Quick Reply: Will a TH400 bolt directly to a '98 WS6?
