Tranny Cooler and Lines...
I'm going to go alittle over kill with my tranny cool lines. I'm looking at running A/N fittings and braided S/S line. Has anyone that has a TC run s/s lines or A/N fittings? Also anyone that has a tranny cooler on a GTO, what cooler did you go with and how long are the lines that you ran from the cooler to the tranny?
Also can someone PM me the info on Pro-Built Automatics, I want to get one of their modded Trans-Go shift kits. Anyone that has one, how do you like it as well.
Restricted User
Biondo, found in Jeg's/Summit under the transmission section, has a nice high pressure quick-release fitting set. Not sure it will screw into the 4L60E, but I plan on getting something like it for my TH350.
Restricted User
Originally Posted by Blown SS
I just did a 4L60E swap , used 18' of -6 AN , 2- strait fittings , and 2-90 deg. fittings. The trans uses a 1/4 x -6 AN fitting , Good Luck
