How Much Stall Do I Need?
I Have A Ls1 With Stage Ii Heads, Tr230/224 111lsa, Lt's Ory, 3.73, Fully Man. 700r4, And A 150 Wet Shot On The Way.
Any Info Would Help Pick A Converter.
Thanks.
Thanks.
Thanks.
Thanks.
Take a look on the Yank website. They've got a converter selector that can probably get you started in the right direction. It looks at gears, mods, cams, etc., and makes suggestions.
Ed
I'd probably go with something like a 3600. I like them a little looser, but with the nitrous on there, you'd probably want a little bit of a tight converter.
And then, it also depends on what your have your shift points set at.
