Trans Trouble
Old 01-01-2006, 05:11 PM
phantomzer0's Avatar
Default Trans Trouble
hey guys i just got my stock 97 a4 rebuilt, and i put it in, but heres the problem, the car doesnt want to move, i can get it to go when i press the gas more than nessicary, also, reverse is the same way. what is wrong?? what shoudl i do? i feel like i dont have enough trans fluid in, but ive already put in 5 1/2 quarts. any one know what the problem is?
one more thing, i read that the torqe converter is supposed to have like 4 quarts of fluid in it itself, but i couldnt get more than one to fit in, could this be the problem?
Old 01-01-2006, 06:09 PM
EDS01SS's Avatar
check your fluid again.If the tranny was rebuilt then it will take alot more the 51/2 quarts.If i remember correctly it takes about 10 quarts if the converter is also close to empty.
Old 01-01-2006, 06:17 PM
slimcracka's Avatar
when i had mine rebuild a a while back with an empty verter.. it took a case...12 quarts.. your doin damage to a fresh tranny if your driving it like this with only 5 1\2 quarts in it..
Old 01-01-2006, 09:36 PM
omg thank you guys so much for your input, i havent drivin it, just tried to get it to move, ill put the other 6 quarts in tomorrow!!!!! ill post with results
Old 01-02-2006, 01:58 PM
alright guys so i put in the rest of the fluid and it works, thanks a bunch
