trans go shift kit
only advice i can give you is to take your time,watch the video a few times for refrence and go by the paper instructions. You will also need programming done to remove torque management otherwise you will have shifting issues,mainly if the computer sees a hard shift it cuts back power(alot of power) untill the torque level is under the limits set for torque management. You will need it either programmed out or lessened..
hey Iwant to put a shift kit put in my ride do you recomend it if the tranny has 121000 miles on it if I can I'm in socal so the 909 area code is with in reach quote me a price for installation Pro Built Automatics tryed to go on your web site was unable to
