wirin up a A4 to a M6 factory harness ...inside
I posted some pics in the sticky to help others if you have done this can you shed some light for me as I'm trying to keep his factory looking and working like factory with the exception of the shifter lock out switch since I keeping the factory M6 column as I perfer to use the push button to remove key.I know theres suppose to be 6 wires from the shifter but I'm only going to use the Park/Neuteral and reverse light wiring...other 2 wirews are for the lockuot switch I dont care to push brake pedal to get out of gear as I allway do that anyways.
