Has any one gained MPH with fuddle?
I was going to buy a TCI 4000 convertor...and then fuddles started getting popular...most people using TCIs were reducing ETs by .5 or so...AND picking up some mph...
It seems like every before/after fuddle install post I read...they loose some ET but the mph drops by a few...Im just curious of the peoples setups are not right or if the stalls are very inefficent.
same mods i have now before stall: 8.73 @ 83
after stall: 8.18 @ 80
this is with the stock tune and torque management was REALLY killing my mph. you could literally watch the car lay down between 1-2 because of it. bear in mind i have the transgo full race/high stall shift kit, it was really giving tqm a workout. i lost .55 only in the 1/8 mile with 3 LESS miles per hour.
the only constant i've had to compare is my gf's 99 t/a - stock. it consistently trapped just a hair under 105 in the 1/4, i barely trapped 103. she would obviously pull me from a roll. after the stall and removal of tqm we are even from a 60 punch.
conclusion: the stall did in fact improve my trap speed, the track will tell the story as to how much. figure this man: i lost .55 with tqm eating me alive, just in the 1/8, what would i have lost if i had it tuned prior to?
Oh, and I lost 3mph with it.
Before new 3800/2.4 fuddle install: 14.21 @ 103.5
After install: 14.04 @ 104.1
I also had a run of 14.13@104.7. On every run I had a lower time and a higher MPH than my runs that were done before installing the Fuddle converter.
I couldn't get any traction to save my life tonight. Any launches I did power braking resulted in horrible 60 foot times due to taking forever to get any kind of traction. My best run was accomplished just mashing the petal. I blame my crappy continental tires. I need something better!
,or
. I mean why give up hp because you want to drop et, you should get the best of both worlds. I hope to be about 113 the next time i go to the track (gaining 1mph from the converter and .5mph from the pulley)Keep in mind that when people say they lost mph or gained mph they might not be factoring in the same track conditions, especially the density altitude (DA).
,or
Looking at results, I see no confirmable evidence that Yank is outrunning Fuddle in any way. Yank seems to say it a lot. But the results we see don't back them up. I dropped ET, gained MPH, AND paid a hell of a lot less. And I am not the only one.
