Has any one gained MPH with fuddle?
Looking at results, I see no confirmable evidence that Yank is outrunning Fuddle in any way. Yank seems to say it a lot. But the results we see don't back them up. I dropped ET, gained MPH, AND paid a hell of a lot less. And I am not the only one.
If you want the best of ALL worlds, go Fuddle.
https://ls1tech.com/forums/drag-racing-results/273788-quickest-stock-internals-list-11-82-bump.html
There is plenty of evidence that Yank performs.
thats a reason how trap speed can become a factor.
12.2 @ 112 1.83 60` on some ET streets...after tune....
Previously it ran 12.6 @ 110 on nittos with a 1.93 60` before I tuned the car for 3.73s it was wacking the rev limiter for a while on the 2-3shift which is why I think I picked up MPH after the tune.
So if both 60's are the same for 11.9 @121 and 11.7 at 116 lets see who wins. Bottom line you want to get the lowest 60ft while getting the highest mph from a converter IF this wasn't true you wouldn't even hear the term EfficiencyI am not saying fuddle is not a good converter, just arguing the point of mph
what raceweight are you at and get an LS6 intake on that biach...will give at least 1 more mph if not more
i made a post about my fuddle experience. i had a yank in the car. this is my 10 second 3500 lbs drag radial car with stock heads and a small nitrous shot. i am happy. enough said.
Very true.. 3700 lbs cam only car here (ran 11.88 on stock fronts and ET Streets). Do your research and buy the stall that is aimed at your goals.
and the converter was unlocked the whole time.
