A4 fluid change - I might have broken something....
Old 02-10-2006, 09:34 AM
nameisnana's Avatar
Default A4 fluid change - I might have broken something....
I dropped the pan, emptied the fluid and took out the filter. I was attempting to take out the filter neck/gasket to replace the new one, but I saw something fall. It was about a 1cm x 1cm piece of very thin metal. I looked up and saw another piece, about the same size, hanging next to the filter neck opening. It was partially attached, so I pulled it off. The problem is I don't know if I broke something important, or if it was just an insignificant piece of thin metal.
Here's a pic to see what I mean......
Attached Thumbnails A4 fluid change - I might have broken something....-100_1730crop2.jpg
Old 02-10-2006, 12:46 PM
joecar's Avatar
Pics of the metal pieces...?
Old 02-10-2006, 12:49 PM
nameisnana's Avatar
Sorry, I didn't take pics of them.
However, if you notice the opening in the pic where the pieces came from, they are much smaller than the opening. Together, the 2 pieces would not be enough to close the opening. It seems like they were just attached to the housing, but not enclosing anything.
Old 02-10-2006, 08:02 PM
nameisnana's Avatar
ttt - before I put this piece of crap back together and see what happens.....
Old 02-10-2006, 10:13 PM
joecar's Avatar
Can you describe the metal pieces, are they part of the case or the drum...?
