Can a trans be hurt by?
Can a trans be hurt by haveing the torque converter lockup disabled. i have a oldsmobile im driving temporarily but the car had a lockup selenoid problem so i just pulled the plug to disable lock up. can this cause damage i wouldnt think so being some transmissions dont even lock. i would just loose gas milage correct.
ok thanks thats what i figured, my mechanic told me "oh dont drive like that youll burn up your trans" but it didnt make any sense to me why.. if anyone else has some input its appreciated
Originally Posted by rgaynor85
what if it was only driven like 35mph on back roads no highway
the problem is that the cooler circuit is tied into the lockup and the cooler recives only about half the converter/lube oil without going into lock up. so if you dont it will heat up too high and have lack of lube oil to worry about.
