Just put B&M supercooler on dope style
Old 03-16-2006, 11:54 AM
Cobra Commander's Avatar
Default Just put B&M supercooler on dope style
is it supposed to get that hot?
I can still touch it but only for about a second or two after a 20 mile drive.
Old 03-16-2006, 11:57 AM
BlackHawk T/A's Avatar
Not sure, I can't reach mine to test...
Old 03-16-2006, 12:05 PM
Moderator
jimmyblue's Avatar
Dope style will probably not see much air until you are rolling.
It is not close-coupled to the fans and air probably prefers to
sneak around, rather than through. You might consider adding
a 12V PC muffin fan or something, if you find it's not doing
well (as seen by ATF temp readings) at low speeds.
Old 03-16-2006, 12:20 PM
2001NBMZ28's Avatar
Mine gets pretty hot - gotta figure it's had at least 185 or so fluid running through it.
Old 03-16-2006, 12:48 PM
yeah I had no choice with the FTRA on
Either way it's still better than nothing.
Old 03-16-2006, 01:10 PM
2001NBMZ28's Avatar
No problems with mine in 3+ years.
