tranny cooler ?
Old 03-21-2006, 03:10 PM
Mach1killerls1's Avatar
Default tranny cooler ?
i had my 3200 stall put in at the end of last week and have yet to put a cooler in it. haven't really driven it around much but then again its been 31 degrees here. my question is i bought a cooler before i knew what to get and got a 10,000 gvw cooler is that going to be good enough for cooling or should i add an additional cooler to that one considering i just got a 15,000 gvw cooler for free. also when you guys install your coolers do you run them alone or do u go back into the radiator? thanks in advance
Old 03-21-2006, 03:53 PM
MattDZ28's Avatar
You still need to route your cooling lines back into the radiator.
Old 03-21-2006, 07:11 PM
ExceSSive's Avatar
Go back to the radiator, and you need more than 10k most go with 24k.
Old 03-21-2006, 11:14 PM
DanZ28's Avatar
I would by-pass the radiator. Why have the radiator heat your tranny fluid up? If you talk to TCI or any other reputable tranny builder, they will tell you to by-pass the radiator so your cooler is an independent system. I would sell the two you have and buy one 24K unit, or you can daisy chain your two together as well, up to you..
