!!!!! NEED HELP FAST PLEASE Fuddle T/C !!!!!!!
I have 3400 fuddle stall and I'm installing it in the morning at buddies house!!
the question is do i need smaller bolts for the T/C or are the stock ones fine?
I heard the the stock ones are to big? need help fast, the install is in the morning!! and this is the only time i can use my buddies lift.
I've searched and could not find anything on a fuddle stall needing smaller bolts.
so if anyone can help please let me know if need smaller bolts and what size.
thanks
thanks
I don't know if you need to shorten them with the fuddle convertors. You could always put a die on backwards and then take them to the old grinder. Remove the die to clean up the threads and your good to go. I'm thinking this is a cheap easy fix. 10mmx1.5 die, grinder and your done! Oh yeah don't foget to bring cold beer!
I'm offically the LS1Tech idiot
I grabbed the stall this morning just to look at it and low and behold there are bolts in it
Thanks for your speedy help guys! and two 24 pack of bud light are going for the install to.
thats the price to use the lift (stock my buddies fridge)
