Help:TH400 LS1 Starter Problems
Old 04-17-2006, 09:57 PM
kwik_ls1's Avatar
Default Help:TH400 LS1 Starter Problems
I put a TH400 in my car this year and I bought a TCI flexplate from LS1speed specifically for a LS1 TH400. I bought a brand new stock starter and when I try to start the car it just grinds. I tried shimming the starter and it made it worse. I am not sure if I am supposed to use a different starter or what I should do. If anybody can help me, it would be greatly appreciated. PM me or post on here or email me direct at tmorales@wfwhelan.com
Thanks.
Tony
Old 04-17-2006, 11:38 PM
SUX2BU's Avatar
whats the flywheel andstarter part numbers?
Old 04-18-2006, 08:26 AM
kwik_ls1's Avatar
I am not sure on the stock starter part # but for the flexplate it is a TCI part # TCI399753. Do I need to use a different starter or something?
Old 04-18-2006, 05:57 PM
SUX2BU's Avatar
are you sure its the starter grinding on it? have you tried turning the motor by hand? i had to grind down the converter bolts when i installeed that flywheel cause they were hitting some bolts on the rear enginecover.
Old 04-22-2006, 01:23 PM
kwik_ls1's Avatar
All I know is that I put a brand new stock starter in and the TCI flexplate part # 399753 and it grinds bad whenever I try to start it. Any help please!
Old 04-22-2006, 03:46 PM
cablebandit's Avatar
is the flywheel flat...on backwards? using a spacer on the wrong side?
Old 04-25-2006, 02:16 PM
kwik_ls1's Avatar
all fixed, thanks for all of the help everybody, the car is up and running now.
Old 04-25-2006, 06:48 PM
Restricted User
CAT3's Avatar
kwiw, what was the issue? Improperly installed flexplate I am guessing.
No spacer is needed with the ATI or TCI models FWIW.
Old 04-25-2006, 08:43 PM
kwik_ls1's Avatar
For some reason I had to shim the starteron the outside bolt. It was weird because I ahve never had to do that before but I had to this time. It works now so that is all that matters.
Thanks.
Quick Reply: Help:TH400 LS1 Starter Problems
