is there an aftermarket shifter for a 4l60e
Old 05-19-2006, 12:19 AM
import slayer's Avatar
Default is there an aftermarket shifter for a 4l60e
all of the after market shifters that I have seen are not compatable w/the 4l60e tranny are there any that are
Old 05-19-2006, 02:01 AM
oner's Avatar
Yeah, I was wondering the same thing.?
Old 05-21-2006, 07:01 PM
Casper9T9's Avatar
There are shifters compatible with the 4L60e, just no direct fit for our cars.
Old 05-22-2006, 02:02 AM
revtime's Avatar
I had an 88 IROC years ago and B&M made a megashifter that dropped right in and looked great.
We 4th gen owners are not so lucky.
You can get almost any shifter to work so long as it will work with 4 forward gears. Alot of the aftermarket shifters will.
The rub is you have to do a custom install of the shifter ........mounting it on the floor and then modifying the console to work without it looking like crap.
When I still had a 60E I used my B&M Pro Stick with it. I had it set up just using 2nd 3rd and 4th but it worked fine controlling the tranny and if I had bought a 4 speed gate plate I could have used all the gears.
I have since replaced my failure prone 60E with a built TH400 with RMVB and I simply changed the gate plate on the shifter.
It takes some thought and you need halfway decent measureing and rudimentary fabricating skills but it can be done.
Old 05-22-2006, 02:48 AM
staringback05's Avatar
sooo do u already have a shift kit? etc etc...or are u just wanting a shifter? i mean without the right stuff ur not just planning on shiftin that auto are u?
