Gonna have my mechanic reinstall converter..
Old 05-30-2006, 05:04 AM
Gun5's Avatar
Default Gonna have my mechanic reinstall converter..
How to tell if its not toasted?? although i never heard of one being toasted... its a 2800 VIG so it should goto 2800 between shifts right?
Old 05-30-2006, 06:35 PM
calongo_SS's Avatar
Are you asking what the shift extension will be? What the rpms drop to when it shifts wide open? It should be much higher than 2800 w/ a vig 2800, probably 4200 - 4500 or so would be my guess.
Old 05-30-2006, 07:49 PM
12secSS's Avatar
What makes you think something is wrong with the converter? If the converter was installed incorrectly, chances are you trans would not function. Typical mis-installations destroy the trasnsmission pump as soon as you fire the engine up. A Vig2800 will not come down to 2800 after the shift, like previously posted, it will be around 4500 rpms and feel like it is slipping when coming off from a stop light ... compared to a stock stall.
Old 05-30-2006, 07:52 PM
BlackHawk T/A's Avatar
From what I gather from this, you expect it to rev to 2800 at part throttle?
Not going to happen without a heavy foot with that converter. I have to push mine quite a bit (without going WOT of course) to get my SS3600 to run past 2800, usually happens when going uphill only.
