Trans leak after TC
Old 06-11-2006, 05:31 PM
gavspurplez's Avatar
Default Trans leak after TC
installed a TC in march, i think.
anyways,
i noticed that if the car sits in the garage for a week, there is a quarter sized spot on the floor of trans fluid.
right about the spot of the factory cooler lines
took it to work and had my friend ( who installed it ) take a look.
he disconnected one of the lines, did something and then installed it again.
seemed to be ok for a couple weeks, but then again the car has not sat for a week.
it sat for a since last week and noticed today the same size spot.
taking it to work tomorrow to look into it further,
anyone have any info or suggestions to what is going on
Old 06-12-2006, 09:04 AM
bump,
monday
Old 06-12-2006, 02:23 PM
just got back from work,
looks like the seals inside of the accumulator are seeping.
that is where the leak is coming from.
can these seals be changed with the trans in the car ??
my tech said it should be able to be done that way.
trans specialists please post up
Old 06-13-2006, 11:31 AM
bump for tuesday
Old 06-13-2006, 08:18 PM
FLT
FLT's Avatar
The band servo seals can be changed in the car. However they normally dont leak. You might want to make sure that the dipstick boot isn't leaking or the pan gasket. Good luck, Vince.
Old 06-14-2006, 08:09 AM
thanks for the info.
if you take a pry-bar and "compress" the accumulator, it will seep fluid.
pan gasket and boot are ok
