Lost lockout...
Lost lockup...
I lose lockup as soon as my trans. warms up. Any ideas on what this would be from? Its a Fuddle 3800 stall is that helps.
i can't say for sure,but my first Yank did that same thing.
Turned out i had a few chunks out of the lock up clutch material inside the filter.
Not enough to lose lock up all together,but once warmed up it would have a pressure leak and then no more lock up.
Yank, replaced the lock up clutch and went through the vertor(under warranty) and all is well again.
Just pieces of clutch material had pulled/ripped off the clutch itself.
i pulled the trans filter out and cut it open and found (LITTLE PIECES) of tan type material inside it.
Pull the pan and see what's up is my suggestion
Good luck !
Dave
Good luck !
Dave
