Please Help I think I have a tranny problem.
I was driving my car on the highway A4 and punched it took it to about 130mph. Everything was fine. Slowed down to 60mph and noticed that the car was like bogging. So I put the car in nuetral and revved it and it was fine so then i put back in drive and when i would push the gas pedal any more than a tap it would like struggle to move. the car still drives just not that good. I dont think it has to do with the motor bc engine idles perfect, not running hot, no noise from motor, revs in nuetral perfect, no check engine codes. also when i got off the highway and was driving on the streets to go home i noticed that i kinda hear a whine from the tranny as i accelerate and i never heard it before. before the pull on the highway my car was running in tip top shape. Any input will be greatly appreciated. Oh also its a 96 LT1 transam ws6. Thanks
well....since you have an lt1 and took it to 130 mph...given the duration of time needed to do so, you might be low on gas.
nah really my car did the same thing when my plug wires went bad (i had a 94 z28), ultimately they started arcing, which caused the car to misfire.
sounds like something fuel/ignition related. i bet your tranny is fine.
lol hey its got all the bolt-ons it aint thatttt slow. yeah i had like 3/4 of a tank of gas. i think its the pump if not ill just change the plugs then wires then opti. thanks for all your help
