Which 4L60E do I have?
Old Jul 18, 2006 | 06:48 PM
ABrianBaker's Avatar
Default Which 4L60E do I have?
Here is the info off the transmission:
CASE 41GMPT 4L60E, M30, 24200873. BELL 24206579. TAIL 24200875-5. and the PUMP 24201073 G-66 D
If nothing else where do I go to find out which one it is? Thanks for the help!!!
Old Jul 18, 2006 | 08:45 PM
waterbug1999's Avatar
Dude.. You have a 4L60E. Looks like those other numbers are for the BELL housing, TAIL shaft, etc...
Old Jul 18, 2006 | 08:49 PM
Yeah but looking at the bell housing it doesnt look like the ls1 style 4l60e. I know there are different kinds.
Attached Thumbnails Which 4L60E do I have?-4l60e2.jpg   Which 4L60E do I have?-4l60e1.jpg
Old Jul 19, 2006 | 05:51 AM
8a8mfh's Avatar
Thats a non LS1 4L60E.
Old Jul 19, 2006 | 09:48 AM
Can it be converted into a LS1 style 4l60e?
Old Jul 21, 2006 | 12:59 AM
Lethal_Ws6's Avatar
How can you tell ?? is there something that identifys a ls1 4l60e ..
Old Jul 21, 2006 | 05:25 AM
8a8mfh's Avatar
An LS1 4L60E will have a bolt hole on the top, and no smooth 1/2" diameter pilot on the end of the input.
I guess to convert it you'd need to change the input/drum, pump, and bellhousing.
Old Jul 21, 2006 | 11:33 PM
Does anyone on here know of any one who has done this? It does't sound to hard. It appeart that the 4l60e that I have i from a LT1. I wonder if i was to do the flywheel and spacer conversion if that would work as well???
Old Jul 22, 2006 | 06:09 AM
8a8mfh's Avatar
Yes the flywheel and spacer set up will work fine. You'll only have five bolts holding it on instead of eight but many people running th350's and th400 are bolted up the same way.
The problem with converting it is finding the parts. There are a few transmission hardparts suppliers around my area that can get good used parts.
And an LS1 converter obviously.
Old Jul 25, 2006 | 07:57 PM
I have heard of a LS1/LT1 converter from Yank. Will that enable me to bolt it right up with out changing anything else and using the spacers?
Old Jul 26, 2006 | 06:19 AM
8a8mfh's Avatar
Yes thats a regular converter with an LS1 crank pilot, that will work also. With no spacers or anything.
Old Jul 26, 2006 | 06:59 AM
joking511's Avatar
That’s not out of a F-body. Look at the tail housing there’s nowhere for the torq arm to bolt up. It’s most likely out of a late model truck. Notice the removable bell housing. You may could change the bell housing and tail housing and be ok.
Old Jul 26, 2006 | 05:29 PM
8a8mfh's Avatar
I do believe we've covered all that.
Old Jul 26, 2006 | 06:29 PM
1BadDime's Avatar
Looks identical from the 4L60E out of My S-10. My bets on that it's out of a Pickup...S-10. Sierra/Silverado etc.
Old Jul 26, 2006 | 10:21 PM
Sweet... That is what I was hoping for. I will check into that further...
On a side note will a 700r4 tail housing bolt up to a 4l60e?
Old Jul 26, 2006 | 10:41 PM
8a8mfh's Avatar
No, not on this one. Early 4L60E's had four bolt tail housings like the 700's, yours has a six bolt.
Old Jul 30, 2006 | 01:49 AM
Just to state the obvious on this one I went ahead and made sure that it would botl up to the back of the engine...... and it would all but two bolts one at the to and one at the bottom...I guess we knew that one.
I am now second guessing that this is a LT1 4l60e. I thought that the lt1 4l60e had the half bell housing with the dust cover.....
if this is out of a s-10 or the like, I wonder if the lt1/ls1 yank converter will work........
the damn sticker that has the identification letters is missing off of the trans. Does anyone know of any where else that the 4 digit code would be located on the trans?
boy this is fun lol
thanks for the help guys!!!
Old Jul 30, 2006 | 07:33 AM
L-EATER's Avatar
11 Second Truck Club
That is a 1998 truck trans. As far as I know it is the only year of the removable bellhousing type '60e that is set up for a regular ol SBC. I put one of those in a '96 truck which orginally had the one piece trans. It worked fine even though I was told the electronics mught be different. I traced the pinouts in the service manuals for a 1996 and a 1998 and they were all the same so I couldnt see why it would not work, and it did.
I cant remember about the input shaft, but I took measurements of the 98 trans against an '02 LS1 '60e I had laying around and everything was exactly the same except the bellhousing.
Old Jul 31, 2006 | 04:08 AM
Interesting....
Isn't the Ls1 bellhousing a deeper than the others?.....
Looks like I am getting further in my quest you guys have been a huge help!!!!
Thanks a Million!!!
Any futher thoughts?
Old Aug 2, 2006 | 08:21 PM
I found out today after opening the transmission up that it looks to has been recently rebuilt. Good luck on my part. I probably still need to upgrade the usual parts however just to be safe!!
