converter help
converter help
well stuck with this dacco 3300-3600 non lock up converter.Whats the deal with this lock up thing some say yes install other say no. Need a little advice thanks.
how about viliglante will it work fine .with high stall will it be able to lock up and will it not heat up any more info would be great
Without a lockup TCC you run the risk of overheating your transmission. One of the things a locking clutch does for the 4L60E is keep the fluid temps down by mostly eliminating slippage (which is what torque converters do).
I wouldn't run a non-lockup converter without a really good transmission cooler.
