3500/4000/4500 stall???
Cam is a 244/248 .600+ lift intake/exhaust
Stage 2 5.3 heads
Forged 347
200 shot
28'' tire
Either a 3.73 or 4.10 depending on what feedback I get from here.
I have a TCI3500 but was considering trading for a fuddle 4k and then sending it out to have it restalled to a 4500. What should I do?
Thanks
Stage 2 5.3 heads
Forged 347
200 shot
28'' tire
Thanks
Yeah but I am building a 9 second setup here. I need to know what stall/gear ratio is going to put me at the ideal setup for N/A and for nitrous. I think the cam may need a 4500 just to idle properly haha
Moderator
I would probably keep the 3500 stall and run the 3.73 gears with the 28" tires. With your combo (strong engine and N2O) I would be worried that you might not through the 1/4 with the 4.10 gears.
John
John
John
John
NA no. With a 200 shot yes.
John
John
Originally Posted by HaulinHawk
Im with him.200 shot=3.73.
I have a 3.55 in there right now. If I end up putting a th400 in the car I may leave that gear to see how the car does. but it equates to like a 3.08 with that tall tire. Car always bogged before but wasn't making near the power it will be now. I am mainly just undecided on stall. I am leaning towards a 4000 though.
Moderator
Originally Posted by I8URLS1
Well car will be driven on the street a lot. So I want something that will be best all around. I'm thinking of just throwing a 4000 fuddle in and see how things are. The stall wouldn't have anything to do with me running out of gear on the nitrous would it?
The 4000 stall converter will have more slip than the 3500 converter. It might hurt you by 100-200 rpm on the 200 shot.
I think I would do just what you suggested, leave the 3.55 gears in there and go with the 4000 stall. Make a few passes and let the results point you in the right direction for your gears.
John
John
John
Yup seems to make the most since. Easier to change the gears out after I see where I stand with this gear/tire/stall setup.
