Is it hard to change a manual valvebody BACK to an electric valvebody
Old 12-17-2006, 08:17 PM
ABeasst's Avatar
Default Is it hard to change a manual valvebody BACK to an electric valvebody
What is required to change a manual valvebody 4L80 back to an electric valvebody 4L80? I am new to autos so dont beat me for not knowing.
thanks
Old 12-17-2006, 09:21 PM
FLT
FLT's Avatar
If you have the transgo kit HD-3 kit, if I remember correct you will probably need a different valve body. This is because they have you drill extra stuff over the HD-2 kit. Sorry for the bad news.
Old 12-18-2006, 02:12 AM
LS1Tech Sponsor
performabuilt's Avatar
Best option is to find a valve body and change it out and do a non manual shift kit with it , would probably be the simple way if your doing it your self
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-18-2006, 09:30 AM
Yank's Avatar
Yanks 4l80-e valve body package can change from auto to manual mode with out destroying the main housing
If you have the Yank unit.
Old 12-20-2006, 05:00 PM
cablebandit's Avatar
get a stock valvebody and then put in a rossler tbrake FTW!!!!
Old 12-20-2006, 10:16 PM
ABeasst's Avatar
Basically what I'm getting at is would JUST changing the valvebody back to a stock one make the tranny back into an electronic shifting transmission.
Old 12-20-2006, 10:20 PM
LS1Tech Sponsor
yes it should no problem
__________________
Call 888-744-6542
