trans problems
Old 01-22-2007, 11:06 PM
hack_1jr's Avatar
Default trans problems
I have a 2000 camaro ss with an auto in it. If i put it into drive, hit always hits the rev limiter from 2nd to 3rd even though i turned down the shift points. But if i start out in overdrive it never hits the rev limiter. No idea why and no one else does either. Any help would be great
Old 01-22-2007, 11:31 PM
LS1Tech Sponsor
performabuilt's Avatar
Well this has been debated over and over but here it is simple the difference is the overun clutch comes on during the 2-3 shift in the drive position so it takes more time to make the shift so you hit the rev limiter before the shift happens , X amount of fluild another chamber to fill and lots of delay, In the od position the overun clutch does not come on during the 2-3 shift though if its severe if may indicate excessive 3-4 clutch clearance and a coming failure. Hope this helps
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 01-23-2007, 10:56 PM
BubaGumpShrimp's Avatar
get a real programmer and be done with it. Stop playing with hypercrap programmer..nuff said.
