Cam only surging...big stall effects?
Old 04-25-2007, 10:09 AM
Mr.MartyStone's Avatar
Default Cam only surging...big stall effects?
Car is cam only 98 M6 going TH400 w/ RMVB conversion. Will be 3200 lb raceweight running a 28" tire, 3.42 gear (will be 3.55 eventually, not much diff.) and looking at a 4400 or so stall verter (custom edge verter) with intent to spray 100-150 shot.
If I have mild surging issues at low speeds now, what can I expect with the TH400 and 4400 stall. I understand there is no engine braking on the Th400 because of a removal of the first drum band (or something of that nature). Will I still get the bucking sensation like I do with the M6 setup?
Thanks,
Marty
Old 04-25-2007, 06:49 PM
BlackHawk T/A's Avatar
The converter will likely make your car stall, literally. Mine has a rare chance of doing it to a bone stock motor, if the conditions are right.
Once you get the tuning figured out it will be fine, but after the install it is going to want to die when coming to a stop.
Old 04-25-2007, 06:54 PM
'Trust''s Avatar
I would imagine you get less bucking with any stall, it is a looser connection between the tranny and engine (where most of the drivetrain loss for autos comes from), and since your converter wont be a lock-up converter (I'm assuming since you didnt denote that it was a TH400e, sorry I'm not sure what RMVB means) that you wont have to worry about just making sure car locks-up the converter at a high enough speed to stop the bucking.
Old 04-25-2007, 07:09 PM
Ragtop 99's Avatar
The fluid coupling of the converter combined with its heavier weight generally makes bucking a little better. Not to mention a 4400 stall is rarely going to see less than 1600 rpms, even in a light car.
Old 04-25-2007, 10:30 PM
Moderator
jimmyblue's Avatar
I think the lighter flywheel mass magnifies surging. What I have
been finding in trying to tune my new cam idle is, you want to
rework the timing table particularly, and probably the fuel as well
to eliminate the MAP axis variation at the low end. This (MAP bump
makes timing drop and fuel richer, making MAP rise more, then
overcorrect the other way, on and on) has to be pounded flat.
Although the timing tables reference dynamic cylinder air this is
MAP, pretty much, until you get to airflow limited.
