4L60e Fluid Capacity?
Old 05-15-2007, 10:23 PM
The LT1 That Could's Avatar
Default 4L60e Fluid Capacity?
Having hell with a leak from VSS, tried to replace o-ring, o-ring not even there when I pulled the VSS out of the case, figured that was the prob.....had troubles getting o-ring to sit flush...nowhere for it rest, no idention in case, nowhere for it to sit on the VSS and "seal" against the case, said **** it...put it back on without, refilled, maybe too much.....leaking worse now
**** IT, changing filter and gasket 2morrow....whats the capacity of the 4L60e??
if it still leaks after this, Im, first off, kicking the car and throwing tennis ***** at it....then putting in a TH350 and giving up on the son of a bitch.
Old 05-15-2007, 10:29 PM
the_merv's Avatar
If you drop the Pan it will take about 6 quarts..just put in 5 and check it from there.
Originally Posted by The LT1 That Could
if it still leaks after this, Im, first off, kicking the car and throwing tennis ***** at it....then putting in a TH350 and giving up the son of a bitch.
That's ****** great...I can see that now..:
Old 05-15-2007, 10:32 PM
lol, its been a fun few days fixing lil misc BS on this car, lol. it deserves a few things thrown at it, haha!
Thanks for the info bro!
Old 05-16-2007, 12:10 AM
don't know the torque spec on the pan bolts by any chance do ya?? repair manual shows 96-120 lb. ft. and thats its....
Old 05-16-2007, 12:19 AM
the_merv's Avatar
I think it's inch/lbs there Herculies..
Old 05-16-2007, 12:21 AM
Revelation Z28's Avatar
that was ******* funny.
Old 05-16-2007, 05:04 AM
daniel6718's Avatar
inch pounds def.....you put silocone on that vss? glob that crap on...
Old 05-16-2007, 05:08 AM
the_merv's Avatar
I've never had to do that..
Old 05-16-2007, 11:35 AM
haha, i am the strongest man alive........def in/lb, lol.
gonna tackle this after work 2night.
Old 05-17-2007, 08:24 PM
miken123's Avatar
by the way - let me know if you used any special tricks to get that trans filter's seal out. I Just tried to do mine this evening and darkness caught me but with a light down there I couldn't get *#@# little sealing ring off the old filter housing... Hanes manual says 'use a screw driver to get out the old seal' but mine's not cooperating.. Let me know how yours went!
Old 05-17-2007, 09:18 PM
meh, decided not to do it. redid the VSS o-ring, and she puked enough fluid to get it at the right level. No drain plugged *** 4L60e...gawd i want TH350!!
I had more **** to tend to, so I decided to hold off on the gasket/filter change. Hopefully the tranny will be out soon, for a verter swap. So, the gasket/filter stuff can wait till then! lol
Old 05-18-2007, 09:06 AM
miken123's Avatar
cool.
well i found another post asking how to remove it and i used a trick someone mentioned of lightly beating on the edge of the seal with a screwdriver and hammer.
Doing this caused the edge of the thing to kink in enough for me to rotate it with the screwdriver (rotate as in make a walll of the cylinder seal face down towards the street).
Then I plucked it out.
Thanks
Mike
Quick Reply: 4L60e Fluid Capacity?
